Transmission leak
Transmission leak
I own a 1999 C5 corvette and testing station have picked up a leak of transmission fluid covering spring hanger rubbers. Anyone else have this problem and what is the possible fix please. Many thanks.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Is it really TRANSMISSION FLUID or is it DIFFERENTIAL 75/90 gear lube FLUID???
Trans fluid in our C5 MN6/MN12 or A4 is ATF Fluid..
What is the actual leak fluid????? ATF or 75/90 Gear lube????
If its stinky 75/90 Gear lube, then its a differential leak/seep
Please check and report back. Give it a taste and see...
