Stock C5 Pinging Question
2002 Coupe, MN6, 161,000 miles, Completely Stock
Has what sure sounds like intermittent light pinging when under load such as going up a hill.
Several peculiar things:
Only happens right around 1500 RPM
Giving it more throttle does not initiate pinging or make it worse.
Seems to happen more/worse at lower altitudes (I live at 5400').
Any ideas or anyone know what is so special about 1500 RPM. I have considered that it may be something else, but it sure sounds like pinging.
While I agree with FASTFATBOY, there are some other things that need be mentioned. Have you done a tune up recently on the car? ie. filter, changes, plugs, and wires....Id like to believe some type of maintenance was done seeing the amount of miles ad still running, but has it been done recently?
Received 1,261 Likes
don't lug the engine uphill at 1500rpm for starters... I'm willing to bet the car is not driven hard and rarely (if ever) sees the upper rpm band, you could have excessive carbon buildup on the pistons... if that is the case a good top end cleaning and some spirited driving can clear that up... also use the highest octane gas available in your area if you aren't already doing that
My brother's C5 had that problem and we determined it was carbon buildup. We live at 4800ft, and the cars seem to run pretty rich up here. I've found BG44k works awesome to clean out the carbon. We ran a can through his car and drove the **** out of it. The whole back bumper was black with soot. It solved his pinging problem.
Run a can or two through yours and see if it cures your problem.
JESSTERLSX (06-09-2017)
personally I prefer to do a top end cleaning where you introduce the cleaner through the intake... in my experience that works much better than any additive you can put in your tank and it also works faster, the results are nearly instant
I was just about to mention this. In my fbodies I used one of the vacuum lines, i think it was the PCV line. I don't remember. Was years ago. But I put it in through that with a friend in the car to keep it from dying.
Yeah, that's the difficult part of doing that with a C-5, because there's no mechanical throttle linkage to modulate the engine speed with.
With a friend in the car, like he mentioned, its all the same. Ive always gone through the brake boost line(which I'm sure that is what he is referring to) with a buddy or my wife to keep it running. I actually just did this for the first time with my stroker and good gosh all mighty did a smoke out my street!!!!
JESSTERLSX (06-10-2017)
Received 3,043 Likes
St. Jude Donor '05
have a 5.3 in a truck started doing that with similar mileage...had been driving it too easy too long as its getting old so lots of carbon
Italian tuneup did the trick, the cleaners didnt do anything. MAF clean a good suggestion!
that's what water/meth kits are for... but your average owner doesn't have one of those already installed... e85 also works great as a cleaner from what I've seen, but again not a ton of people running that either
Hey gang. Car was almost empty today. I put an entire 16oz can of sea foam in the tank and filled it up with 93. Not a lot of smoke or anything. But I aired it out real good with a couple of third gear pulls. Car runs smother and seems to be much more quiet on the engine noise. I put it all in the tank because my gas level sensor is messing up as well so I wanted to see if this would help clear that up. So far so good. It's at about 3/4 of a tank now and it's still working so it looks like I killed two birds with one stone. On the next oil change I might run a can through the intake system via the via the vacuum hoses.
