Best brake pads?
Best brake pads?
I'm thinking about getting into a brake job this week. I'm not wanting to go with anything expensive, just thinking about getting the rotors turned and slapping on some new pads.
You guys think that I should go with OEM pads, performance friction or what? I've always used NAPA gold pads on everything else I've ever had, but I've never had a vette before.
Thanks in advance
Luke
Thanks in advance
Luke
Re: Best brake pads? (billreid1@***.net)
Several forum members, including myself, have gone with the Raybestos Quiet Stop Ceramic pads. They're available at Pep Boys for about $75 for the fronts.
They're great in every way. They seem to fade less than the stock pads plus they throw almost zero dust. :cheers:
Re: Best brake pads? (Mike99C5HT)
Re: Best brake pads? (Chandlerdah)
Where can you buy these pads?
Best Street Pad is the PFC Z by FAR. Try them. :confused:
Re: Best brake pads? (Richin Chicago)
I have to respectfully disagree on the fade part. From what I have seen they fade pretty quickly on the track.
Interesting. I had the car to the track before and after the QS pads and noticed a lot less fade than with the stock pads. The thing I like the most about these pads is that even after a hard track day, the wheels still look clean and there isn't much mess to clean up.
Many folks I talked with at Corvettes @ Carlisle this past August, swear by the HAWK PERFORMANCE pads! :yesnod:
Haven't got them yet myself, but just may. They said that the dusting was minimal too... quite a concern when you have YELLOW RIMS :smash: :smash: !!!
:lol: :cheers: :lol:
Re: Best brake pads? (Chandler)
:confused:
Carbon metallic or Z's...what's the difference.
Z pads seem require roughly half the pedal force for the same stopping distances as OEM and aftermarket semi and full metallics after the metallics have been applied several times.
Z pads seem to stop as quickly cold as they do after they have been applied several times. Forget trying to stop UNTIL the metallics have been applied several times.
After many thousands of miles of using Z pads, the rotor area does NOT look like a brake lathe as it would using the matallic pads. With metallic pads, the rotor area is covered with rotor and pad material unlike Z pad apps. It's amazing to see how long it takes for the Z pads to wear off the rotor machine marks!
I am basing this post on my "living with" my 85 MB 300D, 85 1/2T 2wd 5.0L gas F150, 85 3/4T (heavy) 4wd 6.2L diesel Suburban and 86 1/2T 2wd 6.2L diesel Suburban. I am also using them on 95 thru 2001 1t SuperDuty (actually 1 1/4T) Dodge Cummins Turbo diesel flatbeds at one of my Customers. This is by NO means all the vehicles I have either installed them or recommended their use.
In summary, Z pads are the best performing pads (from ALL aspects) I have seen in my 38 years of experience.
Thanks Rich...I'm going to order the Z's. BTW, how much dust should I expect with mostly street use? :cheers:
I can't really tell you as I had a set but sold them. I do a lot of track time and have decided to stay with EBC redstuff pads for both the street and track. They are good enough on the street so that I don't switch back and forth anymore.
My rule of thumb is big stops mean big dust. Something has to give, particularly if you want a pad that will operate at elevated temperatures. You could go the other way with Raybestos ceramic that don't dust but both the Raybestos guy and my observations on the track say they don't do elevated temperatures well.
The PFC Z's do dust, but not as bad as the Hawks for SURE.
The dust is a lighter color. Somewhere close to stock dust, maybe a touch more. Should be less than '02 Z06 dust.
The dust is the best compromise I've seen.
Wash the car once a week and you'll be ok.
