C5 Cam Install _ Any tips before I start?
I will be starting a cam only install in the upcoming week and wondering if anyone has any last minute suggestions/tips. I will be leaving the heads on and using the TDC method for swapping springs.
I will be using both LS1Howto.com articles (avoiding their method for removing/installing balancer), and the GM Service manual. Thanks.
Parts List:
-25-TSP228R6112 - Texas Speed LS1 Camshaft:
228/228, .600/.600, 112 LSA, 110 ICL
-199-PAC660PRCSpringKit - Texas Speed &
Performance .660" Dual Valve Spring Kit Featuring
PAC Valve Springs
-97-TVS-2187 - PAC .660 Dual Valve Spring, Per
Spring, Nano-Peened, 160 lb. @ 1.80", 415 lb. @ 1.15",
CB @ 1.015"
-25-7400-1 - Texas Speed & Performance 7.40
Chromoly Pushrod (Verifying with Comp Cams checker)
-28-12646386 - LS2 Timing Chain
-122-MEL10295 - Melling High Pressure Oil Pump,
1997+ LSx Based Vehicles (aligning gears using shims)
-28-CamGskKit - Texas Speed & Performance
Camshaft Gasket & Bolt Package
-Stock rocker arms
-Stock lifters
-TSP Tune
-Vararam W/powerduct
-axle back
-TSP Tune
Parts List:
PAC Valve Springs
CB @ 1.015"
-Stock rocker arms
-Stock lifters
-TSP Tune
-axle back
-TSP Tune
Strongly consider doing a trunion upgrade on the rockers. When you run a higher lift cam like that, you run a high risk of the stock bearings failing, and throwing needle bearings into the crank case (yikes).
The Straub bushing upgrade is really nice. It's what I went with.
Also, take a close look at your cam plate. There's an integrated gasket in there that seals an oil galley. Most re-use it, but the part is cheap and an easy swap for cheap insurance. If this gasket fails, you'll have oil pressure concerns.
Otherwise, it's pretty straight forward. Definitely buy a damper installer (I bought one on eBay for less than $20) and buy the front cover alignment tool from Sac City. DO NOT let the cover self-center, because it won't. Ask me how I know...
Also, when you install dot-to-dot, make sure you turn the engine over by hand a few times. and verify that the dots continue to line up. They should, but it's a handy way to see if you're off by a tooth or so. It also give you confidence that you won't have any piston to valve interference issues.
There's mixed reviews on the trunion upgrade, I had them done on a old Fbody heads, cam car. I asked the shop doing the work on my C5 install (sponsor here) and he told me that he saw just about the same about of those fails as the ones without. And im assuming its a mail order tune, even though its there cam I would suggest at least a street tune in the future.
But the stockers really won't last when running a cam with high lift. (more than .575"). When I pulled my rockers and played with them, it's clear that their range of motion is limited. Meeting or exceeding that range won't last long.
Comp uses the bronze bushings now from what I have seen. This is the old post about their failure.
https://www.corvetteforum.com/forums...s-of-pics.html
Interesting from this pic seems they still Might use it
http://www.compperformancegroupstore...Category_Code=
I have this set still NIB but never used it. I also went with the Straub kit
Personally, I would wait on pushrods and measure before buying. Then, buy larger OD like 11/32". The hardened pushrods don't buy you any stiffness increase at all over the stock pushrods. With those springs, 5/16" pushrods will be like a pole vault and will likely bound your valves causing issues down the road IMO.
