Do I Nedd a Tranny Cooler with a Y3000???
Topic says it all. I'm getting ready to put the 3.15 in (at last the 2.73's are going :U) with a Yank 3000 converter and didn't know if I need a tranny cooler oni it. I know it wouldn't hurt and probably is more of a necessity with the more radical TC like SY3500's but didn't know about this TC. :cheers:
Re: Do I Nedd a Tranny Cooler with a Y3000??? (SFVetteman)
We recommend it :)
Using a synthetic ATF wouldn't be a bad idea either.
As with anything you read here on the forum, do not take it as gospel....
Do research, ask around, etc....
But, trust me on this, NO SYN in the tranny!!!
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Re: Do I Nedd a Tranny Cooler with a Y3000??? (indypace78)
We recommend it :)
:nono: Do NOT, I repeat do NOT use a synthetic ATF fluid! Yank does NOT recommend it!
Cruise-In II & IV Veteran
CI VI Drag Champ!
Re: Do I Nedd a Tranny Cooler with a Y3000??? (MikeyD)
I you plan on going the track alot yes. I make over 200 passes year and just put one in. Tranny temp would get as high as 220. This weekend in big heat after 5 succesive runs only 183. Noraml is 165 now.
St. Jude Donor '05
Re: Do I Nedd a Tranny Cooler with a Y3000??? (2000^C5)
Yes, very simple do it yourself installation. Cut out shroud under tranny cooler to allow for air flow.
[Modified by wallstAL, 1:04 PM 9/23/2002]
Hey Mike,
Glad to see you are ready to install the TC. As far as the cooler goes, like what was said previously, it is cheap insurance. The biggest enemy of the A4 is heat, so the less the better. Keep us posted on your results. Also like Ellis mentioned do NOT use synthetic trans fluid. Good luck!
Mike :)
Mike :)
I currently have the Yank 3200 with 315 gears. The converter is great. I've pulled some 1.74 60ft times with this setup. I don't have a trans. cooler. When I talked to Yank, they informed me that I did not need one. So I didn't. This last summer, the trans. temp. reached 208 at it's max. I've mean to the drag strip several times with it and I've had no problems at all. I did have the trans. serviced when I installed the converter. As for me, I will put one on but it might be a while. ( other mods first ) Hope this helps! :D
We recommend it :)
