Window motor shot
Window motor shot
Is there any way to get the passenger window closed until I can replace the motor? I tried the trick of banging on the motor, not working. Door panel is off at this point so I do have access. Thanks for any suggestions.
Changed my mind, she's coming out, new motor is going in today. Wish me luck and please post any hints or wise cracks applicable. Thanks
Well, well, well, GM uses 2 different motors with different plugs, but the same part number. Parts manager says there is a note in the book saying if the plug doesn't fit you need to order the adapter. Should be in Monday late afternoon. I knew everything went too easy.
No, not really. I broke 1 of them previously, but being 14 years old that plastic is brittle. But that does remind me to pick up a package of clips at the parts counter.
