Need tips on How to repair broken vacuum hose that connects back of intake
Pulled off the stock intake off my 03. And ended up splitting the vacuum hose which I am guessing is for the ac/heat. Does anyone have any tips on how to repair it? I am thinking maybe a dab of silicone possibly and a zip tie. Just wanted to see if anyone else has a brighter idea. Thanks!
1/4 mile/AutoX
https://www.amazon.com/APDTY-Vacuum-...25K9X2X8DXZKVC
or just use a piece of hose, doesn't have to be a 90 degree ?? just a different size from intake to plastic line !!
that's just a vacuum elbow. many cars use the same size and same 90deg fitting. did you talk to the parts counter at your local dealership? they may have something similar hiding around
1/4 mile/AutoX
Try the "HELP" parts selection that Advance Auto Parts and Autozone stores both have....
I went to qutozone bought emission dtubing then read dthe manual how to splice. SSSSSSSsi Used vac. tubbcing exacdto sip pver trhe emission dtube, THEn I left enough new tubing to mke a 10d' LOOP. I usws rUBINDG TO MAKE SPLICE AND DDDDDALLOWED THE LLOOP TO OCMPRESSS BACK UNDER DASH AND INSTALLED MANIFOLD. YES I AM STILL WAITING ON NEW KEYBOARD SORRY FOR ERRORS
Received 1,261 Likes
