Steering column locked
Old 08-07-2016, 09:36 PM
hammerdown1953
hammerdown1953's Avatar
Default Steering column locked
I got in my 98 put the key in and turned it and wheel would not move. Showed message, service column lock. Has anyone had this problem? Many thanks.
Old 08-07-2016, 09:41 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,195 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
everyone has had this problem https://www.corvetteforum.com/forums...ky-please.html
Old 08-10-2016, 07:52 PM
Fast20
Fast20's Avatar
LMC5 bypass kit WITH column unlock. Easy to install and cheap on ebay
Old 08-11-2016, 06:46 PM
Velocity_Vette
Velocity_Vette's Avatar
Yes, you need the LMC5 kit WITH the 12v operated unlocker. You cannot properly install the LMC5 itself if the column is locked or can still lock.
Old 08-12-2016, 07:38 AM
steig
steig's Avatar
LMC5, there are many articles/videos written to help you
Old 08-12-2016, 08:52 AM
Gordy M
Gordy M's Avatar
Temporarily you can grab the steering wheel and turn it back and forth until you bypass the locking system, but it will still lock up the next time you use the car. The by-pass is the way to go...cheap, easily installed and a ton of video and printed info on how to do it.
Old 08-12-2016, 11:00 AM
mctwist77
mctwist77's Avatar
Compliance Parts! EXCELLENT customer service, VERY knowledgeable.
To Steering column locked
Quick Reply: Steering column locked
