Will this tire combo work?
305/35r18 Rear
275/35r18 Front
Will I have any traction control issues?
Will be he 305 fit on a stock rear without rubbing?
275/35r18 Front
TC shouldn't be an issue. 305 on Z wheels or base? If the latter that is a squeeze on base wheels.
Unless it is for esthetics, a wider tire isn't always better. Sometimes a narrower tire can have a larger contact patch. That's where the rubber meets the road! Look at the relative skinny tires they use in NASCAR.
Most of the 205 are street slicks. For a street tire I have heard good things about the Nitto NT05 tire. They are sticky and will wear out around 10k miles though.
