Lost some EBCM bolts
Old 05-16-2016, 01:22 PM
ysb02
ysb02's Avatar
Default Lost some EBCM bolts
I was putting it back in the car after getting it back from abs-fixer. Dropped two bolts and after an hour of lifting the car and checking every angle can't find them. Anyone know where to order new ones?
Old 05-16-2016, 08:25 PM
71corv
71corv's Avatar
St. Jude Donor '08
Had the same problem. Got mine from Gene Culley.
Old 05-18-2016, 12:55 PM
ysb02
ysb02's Avatar
Sent Gene a msg but haven't heard back
Old 05-26-2016, 02:46 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
I responded and you placed an order?
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 05-27-2016, 01:26 AM
drtyTshrt
drtyTshrt's Avatar
I bet they went behind the control box. I did the same thing and when I had to remove it again for something else there they were. There is a spot on the back of the unit that will catch them.
Old 05-31-2016, 09:07 AM
ysb02
ysb02's Avatar
Got the bolts from Gene, thanks!
Found one bolt when I moved the car, seems like the other one found a new home.
Seems like ABS Fixer solved my random BCM code-throwing issue.
To Lost some EBCM bolts
Quick Reply: Lost some EBCM bolts
