Wiring diagram needed ... sick of the demonically possessed side mirrors
I'm so done with these GD side mirrors. Every freaking time I get in my car bzzzbzzzbzz ... oh now there's a nice view of the sky/dirt in your side mirrors which btw were perfectly adjusted the last time you got in your car. I've tried cleaning the resistance sliders to no avail. It is not a feature I need nor want. I want to set them in 1 position and have the BCM stop f**king with them.
Looking at the guts, I see an 8 wire bundle going to the mirror module. I'm guessing 4 of those are for the motors and 4 are for the position sensors. And I bet if I can snip the wires to the sensors, the BCM will read infinite resistance all the time and thus will stop trying to move them around. Yes? No?
Anyone got a wiring diagram for the door?
You can just remove the pins from the connector instead of cutting wires. Let me know if you need any help. Looks like you are ready for the Samuari fix though.
Mr. Sam
I think just removing the 4 pin connector will do it. Just using my memory of the design.
Mr. Sam
On the motor side, all 8 wires are in the same harness. Are they broken out into 2, 4-wire plugs in the door?
since you have it set to #1 are you using #1 key fob?
before you do all that i would set the mirror and program it to #1 & #2 and see if it still moves
maybe you need a priest? it might be haunted?
is it possable you dont have remote 1 & 2?
if you have a replacement remote (#3) maybe you need to program the memory by holding down 1&2 at the same time i think it was or maybe you can just do a reprogram and set it as #1
I just opened up my driver door, and lo and behold what do I find but a 4-wire harness with the colors corresponding to the 4 sensor leads ...
http://corvetteforum.shelor.net/Diag...or_Control.gif
BlackWhite, Dk Green, Gray, Gray (these colors were the lower half of the plug, they switch colors on the upper half)
Popped that plug out and voila! No more memory "feature" for that mirror! I can still move it around with the door controls, but now I'll be the ONLY thing moving them around.
OK, i'm bringing this thread back from the dead. I have the same issue, annoying and unsafe.
I tried exactly this. Unplugged the 4 pin memory connector from each side. It only kinda works?
I thought my issue was resolved after unplugging the 2 4-pin connects. After i did, using buttons 1 and 2 on the door DON'T move the mirrors.
Also, if i lock the doors, and unlock after a short period of time, the mirrors don't move. However -- overnight, or after being at work for the day, or a few hours... hit unlock on the remote -- and sure enough, the mirrors freaking MOVE still -- both of them. But not till i hit the unlock button on the remote.
In ONE instance (i haven't had a chance to try this repeatedly yet): i unlocked the door with the key, sat down, shut the door... THEN pushed the unlock button, and the mirrors did NOT move.
They move differently than before -- they move more in and slightly down -- where before, with the memory connectors plugged in, the moved mostly down, and little in.
SO, is there some sort of default or position that the mirrors try to move to if they don't detect the the signal from the memory feature?
Driving me bananas.
My next thought, if someone can't help:
Put a toggle switch on power wire(s) going to the mirrors, so that they don't work at all in any fashion, unless i toggle that switch on......
Help!?
Driving me bananas.
Help!?
I have the same problem, only with passenger side. Haven't tried to fix it though. It can be dangerous, needing to make a quick lane change to the right and the mirror is showing you the ground. I don't always check the mirror when I start the car and it only does it sporadically.
Ahh yes, I probably should've posted a follow-up to this. Pulling those connectors seemed to work for about a week. Then gradually the problem returned. Now it's as bad as it ever was. I think what I might do is simply cut the power at the BCM. I just need to find a suitable 4-pole, single throw switch which I'll mount under the driver seat. Then I can just get them where I want them, cut the power to the motors, and fahgettabouit.
For folks like Doug1 and others who may want to try cleaning the position sensors, here's the how-to: https://www.corvetteforum.com/forums...262-b2265.html
But I know the solution.
