Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-05-2002, 01:22 PM   #1
Ron Cleaver
CF Senior Member
Default Checking C5 automatic transmission fluid
The owner's manual is very condescending on this, as if we are too dumb to do it. It says to take it to a dealer.
Is it really a big deal? How do you do it and how is it different from any other car. :jester
Ron Cleaver is offline   Reply With Quote
Old 09-05-2002, 02:24 PM   #2
Xssesive
CF Senior Member
Xssesive's Avatar
Default Re: Checking C5 automatic transmission fluid (Ron Cleaver)
You have to check it under the car, there is a sight plug you remove to check fluid level. Go to http://www.idavette.net/hib/C5diy/c5diy2.htm
[Modified by Xssesive, 12:28 PM 9/5/2002]
[Modified by Xssesive, 12:34 PM 9/5/2002]
Xssesive is offline   Reply With Quote
Old 09-05-2002, 02:36 PM   #3
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
Default Re: Checking C5 automatic transmission fluid (Xssesive)
searched and found this:
forums.corvetteforum.com/zerothread?id=216624
Mike Mercury is offline   Reply With Quote
Old 09-06-2002, 01:22 PM   #4
Ron Cleaver
CF Senior Member
Xsessive - that's a good link
Mike - I did a search and didn't find that link.
I was asking because I found a dry red spot on my garage floor after the trans. fluid temp. reached about 200 degrees sitting on the DC Beltway. So I was wondering if fluid overflowed but I couldn't find the dipstick :D
Old 09-07-2002, 03:09 AM   #5
Marcus
CF Senior Member
Marcus's Avatar
:nono: There is no spoon... err dipstick. You have to raise the car level, remove a bolt on the side of the transmission housing, stick your finger in to see if the fluid is up to the hole. If not, you need to hand pump tranny fluid into the hole until it trickles out. :cuss What an annoying and inane process! GM needs to hire better engineers.
[Modified by Marcus, 1:09 AM 9/7/2002]
Marcus is offline   Reply With Quote
Old 09-07-2002, 11:41 AM   #6
Mike Mercury
CF Senior Member
Default Re: Checking C5 automatic transmission fluid (Marcus)
Don't forget it is a mandatory that the engine is running and the tranny in neutral. It needs to be done by the book! :)
Old 09-07-2002, 01:22 PM   #7
RWhite
CF Senior Member
RWhite's Avatar
Default Re: Checking C5 automatic transmission fluid (Mike Mercury)
I did this process a few weeks ago and it is easy, just kind of weird running the tranny through the gears up on a lift with me under it adding fluid! I did not use a pump to add fluid. Wal Mart had a neat clear rubber hose you screw onto the fluid bottle and by just squeezing the bottle, it flows up the tube and into the tranny.
RWhite is offline   Reply With Quote
Old 09-07-2002, 10:58 PM   #8
3BVert
CF Senior Member
3BVert's Avatar
I never thought about why there is not a dip stick but...
That would have to be one LONG dip stick!
3BVert is offline   Reply With Quote
Old 09-09-2002, 01:15 PM   #9
Fast one
CF Senior Member
Default Re: Checking C5 automatic transmission fluid (3BVert)
Or an aftermarket sensor bolt that drives a green and red led for high and low fluid levels.
Fast one is offline   Reply With Quote
Old 09-09-2002, 07:00 PM   #10
JCR
CF Senior Member
JCR's Avatar
Default Re: Checking C5 automatic transmission fluid (Fast one)
I believe that several precepts are being overlooked here.
1. The fluid is supposed to be lifetime???
2. Once it is in , and there is no evidence of leakage there is no need to add fluid. This in theory should be for a lifetime.
3.The engineers did not design this transmission with frequent changes in mind. If you do not see a leak then leave it alone. If you must then fill, then it must be running and all it takes is a little finger probe in the fill hole similar to a differential check. I do not see it as a big deal, especially if you have a lift. Simple if you have the right tools, and GM has the right tools.
JCR is offline   Reply With Quote
Reload this Page Checking C5 automatic transmission fluid
Tags
1997, 1999, 97, atf, automatic, c5, check, checking, corvette, corvvette, fluid, fulid, sip, stick, transmissin, transmission, walmart
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 Tech 252 02-02-2014 12:23 PM
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 12:59 PM
Corvette owner satisfied. drmustang C6 Z06 Discussion 34 06-20-2005 11:10 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
