running rough
Old 07-10-2016, 12:13 PM
painterman98
painterman98's Avatar
Default running rough
just finished installing complete exhaust. headers midpipe and mufflers. went for a test driveand it sounds great and ran perfect for about a mile then started running like it was on 4 cylinders. shut it off then started it back up and ran perfect for about the same distance. restarted in the garage and runs perfect then I just shut it off. any ideas on the cause. It threw no codes
Old 07-10-2016, 12:28 PM
painterman98
I expected to see them
Old 07-10-2016, 01:53 PM
KOZ
KOZ's Avatar
Sounds like you cracked a spark plug
Old 07-10-2016, 02:01 PM
painterman98
a6-scm u1016h u1064h
a1-rdcm b2265h
ao-ldcm u1064h
40-bcm u1016h u1096h b2482hc b0507hc b0502hc
Old 07-10-2016, 02:13 PM
KOZ
KOZ's Avatar
Pull and check all the plugs
None of those codes have anything to do with why your car is running rough
Old 07-10-2016, 03:21 PM
ZigZag
ZigZag's Avatar
Originally Posted by 8VETTE7
You need to check the plugs and the wires since that was the most recent thing changed. Cracked plug or damaged wires most likely.
You added headers, when I did I ended up with two wires that got burnt through. Had to pull them all off to find the bad ones. My car was doing the exact same as you described.
Old 07-10-2016, 03:26 PM
Pounder
1/4 mile/AutoX
Support Corvetteforum!
Pounder's Avatar
Received 2,081 Likes on 1,634 Posts
You will also need a tune !!!!! http://www.eastcoastsupercharging.com/
Old 07-10-2016, 04:30 PM
Nasbluec5
Nasbluec5's Avatar
Get some spark plug wire protectors. As already stated it sounds like cracked plugs. Put some fresh tr55s in it.
Old 07-11-2016, 08:43 PM
painterman98
I changed the plugs and wires. started it up and it runs perfect for a minute or two then rough as can be. I turned it off and restarted it and it runs perfect for a minute or two. so i turn it off and restart immediatly and it runs great so i just shut it off. i have no clue whats going on
Old 07-12-2016, 09:14 AM
painterman98
I cleared all the codes. started it after a minute it began running rough . I left it running and there are no codes. the starter is good for sure. Its hard to tell about the other grounds but they appear to be ok
Old 07-12-2016, 09:38 AM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had the exact same issue after a header install. All looked fine BUT,,, once you dug a little deeper, THIS is what you could fine:
You do NOT have to have a TUNE but,,,,,,,, you will NOT get all the HP/Tq that is on the table from what the header install has to offer and you will loose a little fuel economy until it tuned.
When the engine starts running rough, LOOK at the Check Engine Light. See if it is FLASHING. If its flashing, that indicates a cylinder or multiple cylinder misfires. IF,,,,, you pull up the DTCs "WITHOUT turning off the ignition, you will or SHOULD see a P-300 (misfire DTC).
Bill
Old 07-12-2016, 09:44 AM
DetroitPlac
DetroitPlac's Avatar
When I installed my headers, I replaced the plugs and wires. It was running about as you described, and I started to panic. So I pulled all the wires off and sure enough, I managed to crack one of the brand new spark plugs. Replaced it and it was fine. It's absolutely worth double checking that they're all ok, and heat socks on the wires are a great idea as previously mentioned.
Old 07-12-2016, 09:56 AM
painterman98
I put on new exhaust because I was having trouble with leaks and rattles. It is tuned for headers. I replaced the new plugs and wires with even newer plugs and wires. what I don`t get is why it runs perfect for a short time then runs bad I shut it off and immediatly start it and it runs perfect again. no codes or check engine light
Old 07-12-2016, 10:14 AM
Pounder
1/4 mile/AutoX
Pounder's Avatar
Do you have these wires in the right spot ???
Old 07-13-2016, 09:11 PM
painterman98
I fixed it. I had the o2 sensors reversed. I didn`t know they had to be in a specific spot. it was easier to run the wires the other way . all is well. thanks for the help and concern
Old 07-13-2016, 09:19 PM
73Corvette
73Corvette's Avatar
Thank YOU for posting what your issue was and how you fixed it... nice find!
To running rough
Quick Reply: running rough
