Reduced Engine Power while Autoxing
Yesterday at my race, I was braking coming into a the last left of a slalom and as soon as I hit the brakes, the car went into reduced engine power mode. It happened once while braking about a year and a half ago, but I have had no issues since. I haven't been able to find anything in searching either. Has anyone had this happen or heard of it happening?
A search should have told you that the FIRST thing you should do is use the dic and pull the codes. Post the codes and somebody will likely be able to help.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% on the MARK!
Before you turn the ignition off read the DTCs. The code that caused the issue may have went to HISTORY so, read and post what you have in the IPS now.
I recommend that you clear everything after you jot down what is there now.
Bill
Bill
