Defective exterior @ door
Old 08-30-2002, 04:42 AM
parrish
7th Gear
parrish's Avatar
Default Defective exterior @ door
This is an interesting one. Last week while washing car I discovered a 1/2" crack in the driver’s side door. This crack is all the way through the skin and is perfectly straight about 1/2" from the vertical edge of the door. I pointed this out to my trusty dealership and they took it to their body shop. Come to find out I was told similar cases had been reported and repaired. This will be a three-day job at the body shop to repair. Has any one else out there had this happen? I have an appointment in two weeks to get this repaired. I will continue the thread at that time.
Also I took the ride in to get that pesky drivers side rocking chair fixed. Part number to follow.
:smash:
Old 08-30-2002, 06:03 AM
vk
vk's Avatar
Default Re: Defective exterior @ door (parrish)
It's not anything like this is it?
I had this happen on the passenger side for no apparent reason
[Modified by vk, 4:03 AM 8/30/2002]
Old 09-01-2002, 04:15 AM
parrish
7th Gear
parrish's Avatar
Default Re: Defective exterior @ door (vk)
No the cut or delamination I speak of looks very precise like a razor cut a strait line. It is around the same distance from the edge as yours. It is located around the level of the door handle. It is hard to see with the eye. If you press on the door panel you then see the separation.
Sorry to see your case. Thanks for the post.
To Defective exterior @ door
Quick Reply: Defective exterior @ door
