Engine reduced power
1998 vert automatic, started car to take a little cruise, engine popped and CEL and traction control light on. Reduced power message displayed. Pulled the codes and got P1516 command verses throttle position and C1278 TCS temporary inhibited by PCM. Reset codes and lights still on engine idling high reduced power still on. Shut car off and checked code again still same Reset codes and this time stayed off and car ran as normal. Is the car telling me something? It is cold here in Reno this is the first time I have car out in this low of temp, this is the first winter. All comments appreciated.
I would check the battery to make sure its not getting weak. Also check all the connections to make sure they are not corroding and check engine grounds.
S
S
Could be several things. Not uncommon to get "hicups" also that just "go away".
If issues come back post what codes you get and I will post the DTC diagnostics for you.
If you want the diagnostics for those codes now I can do that too, not at home now.
Mr. Sam
Mr. Sam
reduced engine power
Shortly after purchasing my 2001 I had a similar problem. DIC went crazy, reduced engine power message. I was not far from home so I limped home. I researched the forum and found a post that talked about the connectors in the doors. I pulled these apart and cleaned the connections and replaced and never had the problem since. Here is a link that mentions Bill Curlee's post here on the forum. This is what I did and my problem was solved. Hope this helps.
http://ls1tech.com/forums/corvette-p...lp-please.html
I could not find Bill's post here thus the LS1 that used his post same info though.
A symptom that clears after a shut down and restart could also be the ignition switch contacts burning and going bad.
If the grounds and door connections are not the problem, I would look at the ignition switch next.
Robert Perkins (11-07-2015)
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The 97 &98 C5s had known defective Throttle Actucation Control Modules. The one in my 98 Coupe went bad... Same symptoms.
Fitst things first. Remove the induction system.. Clean/replace the filter. Clean the MAF with MAF cleaner..
Examine the throtle blade and throttle body. The blade and opening will likely be very dirty inside.
Make SURE that the throttle blade can be opened and FLOPS shut when released. It WILL NOT snap shut!!!
It will ERRECT to the last known good idle position when the ignition is ON.
If you still have the issue after you accomplish the above, Inspect the wiring to the Throttle Position Sensor.
REP happens when the PCM detects that what you are telling the engine to do doesnt match to what the engine is doing.
The TAC module is mounted in the passengers fender on the outside of the PCM:
Open this pannel in the passengers fender well:
PCM/TAC TAC on the outside:
Thanks for the info will do tomorrow I guess while I have the induction system removed I will clean out the radiator. I also ordered a new ignition switch because I have had other intermittent electrical issues that will clear but come back in a month or so. If I am gaining access to the switch might as well replace it.
The wiring harness connection at the TAC module had moisture in it causing the same symptoms on my 2001. Problem would come and go. After drying the connection and a little dyelectric grease on the connector seal have no had other problems.
Bill Curlee is correct about issues with the early TAC modules. GM made modifications and if you need to replace it you can use any 99-04 one.
Here are the diagnostics for the two codes.
https://www.dropbox.com/s/l0l2ag8k6r...01516.pdf?dl=0
https://www.dropbox.com/s/bl9b7eyqdh...01278.pdf?dl=0
Mr. Sam
Mr. Sam
Robert Perkins (11-08-2015)
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The issue was covered under a TSB and only addressed if the car had specific issues and DTCs. Mine died AFTER the warranty expired so, I had to deal with it. The module is a plug and play replacement.
Bill
BC
Bill
BC
I worked on the problem yesterday, replaced air filter, cleaned throttle body, cleaned MAF checked connectors all good no corrosion. Test drove car for about 40 miles no further problems. Thanks for all the help.
