Weird Intake Question...
Hey everyone!
I'm looking to get a new intake setup for my '99, as the stock air box is just broken (Latches are failing, doesn't sit right), and I'm looking to add a tiny bit of HP while I'm at it
I've ruled out systems like the Callaway Honker (as much as I want it...) and the Vararam, as this is my daily driver, and I don't want to do anything too crazy. I'm looking specifically at the Airaid, SLP Blackwing, and open air filters like that. I don't really want to do the Zip-Tie mod, as it was the cause of my broken air box
My question for you guys is this: Am I going to need to worry about water coming in if it's raining?
I apologize if this is a dumb question or if it's been answered, but google wasn't pulling much up. I'd really just like to know before I pull the trigger.
TL;DR: Will an open air filter in the rain soak up water?
Thanks guys!
Thanks guys!
I too wanted more air but nothing crazy so i consideed a z06 box, it has a bigger opening for more air but ended up drilling 10,
3/4" holes in my stock box at random locations. This gave me a lot more air intake and still maintained the stock original look. I installed the hood seal as a precaution for water injestion, i have driven through some real hard rainstorms with no issues. You can pick up a used z06 box fairly cheap, 40-50 bucks and if u still want more air drill holes like i did without breaking the bank. Good luck
Forrest,
I've had a Blackwing on one of my cars for years with no problems. I left the radiator shroud intact, and I put a seal along the leading edge of the hood. HTH.
Received 19,430 Likes
'20-'21-'22-'23-'24
I've run a Blackwing on my last two C5s and like it a lot. Easy install, no codes and a bit better performance than stock.
I'd really like to grab both the Blackwing and the Airaid and see if there's any real difference on the dyno, but my current funds wouldn't really permit that I do need to stop speculating and just grab one, though. Thanks!
Thank you guys so much for the quick replies! Looks like a new air filter will be on it's way soon!
Unless you bring in outside ambient air you will not make and meaningful HP gains. The systems you mention all pick up engine bay heated air, however a Blackwing or Donaldson type air intake may help with some intermediate HP gains. When GM was testing the Z06 air box to the standard c5 intake the found almost 2 hp gain but better intermediate response and adjusted the calibration as a result.
I've had a Vararam on for over a year now and have driven in some very heavy down pours... 4" in one hour a few weeks ago near Jonesboro Ark...drove for nearly 5 hours in heavy rain on a trip to Texas and the car has never sputtered or coughed one time...
I am careful to NOT drive into STANDING water, that may come up to the intakes... then your just asking for Hydro Lock...
The Vararam does NOT suck in rain......
IF the water is DEEP enough for the Vararam to suck it up and Hydro Lock... you'd probably be in DEEP enough water to flood your PCM also...
Thanks so much Gordy, I really appreciate your input.
The Plug & Play Filters (So to speak) are my best option at this point, as I've got a failing clutch slave, musical obligations, and college looming on the horizon, but I am hoping to pick up either the Vararam or the Honker after I've come into a less hectic situation.
Thank you so much for the reassurance sir!
Thank you all of you guys putting in your input! It's heavily appreciated.
That makes sense, with my little knowledge of how cold-air intakes work. I would very much like to install a system that would draw air from my useless fog light covers (FRC so no actual fog lights ), but I think that's going to be further down the road of my ownership, when funds and time permit
Well, crap. Now I'm actually considering a Vararam...
Good luck and have fun with it....
Oh Yeah... the Vararam made a feel it in the seat of your pants difference...
1/4 mile/AutoX
