Intermittent reading of RF tire pressure
After about 10000 miles my DIC display for front tire pressure gives me the pressure for the left front tire but nothing for the right front. After driving awhile the right front tire sensor starts sending its reading . Should I reset or is the sensor going bad?
Re: Intermittent reading of RF tire pressure (sandyg)
You should try to reprogram the sensors. There is an article in the Tech Tips section but be warned if that sensor is bad and you attempt the reprogram you won't be able to calibrate the rears and will only have a readout from the LF...I know first hand unfortunately. You might have to replace the sensor.
