Can you change the ring and pinion from 3.42 to 3.90 w/o modding the case?
Old 08-23-2002, 02:48 PM
Horsepower
Horsepower's Avatar
Default Can you change the ring and pinion from 3.42 to 3.90 w/o modding the case?
WCC tells me NO. Another shop(Andys Auto) tells me YES. They said if I have the 2.73's it must be modded but with a current 3.42 the 3.90's will go right in? They also said they did it to a forum members car. Are we being duped by the Vendors into spending more than we need to? I can order the ring and pinion for $400 and I got a quote from my tranny shop to do the change for $400. That's $800 for gear swap out the door. A pretty substantial savings over the $1700 dif exchange plus $400 labor to do the swap.
Old 08-23-2002, 03:41 PM
OliverM5
OliverM5's Avatar
Default Re: Can you change the ring and pinion from 3.42 to 3.90 w/o modding the case? (Horsepower)
The answer is YES - you can swap the gears (you just need new seals, shims, and bearings). I am the forum member you are referring to........ :D
Old 08-23-2002, 03:52 PM
Mike Mercury
Mike Mercury's Avatar
Default Re: Can you change the ring and pinion from 3.42 to 3.90 w/o modding the case? (OliverM5)
there are two cases for the C5 carrier... and only 2.
the one used for the 2.73... and one for all the others. Are you sure they aren't tralking about the reinforced "shaft" inside the case?
Old 08-23-2002, 04:01 PM
Horsepower
Horsepower's Avatar
Default Re: Can you change the ring and pinion from 3.42 to 3.90 w/o modding the case? (Mike Mercury)
So I guess with the new seals and shims and bearings it will put the cost up a bit but still WAY under $2000.
Old 08-23-2002, 04:11 PM
boblackhardtop
boblackhardtop's Avatar
If you have a 3.15 carrier to swap you can get it for way under $2000, closer to 1/2 of that. Not worth the hassle of trying to rebuilt it yourself. I did the math & end up buying one from Andy. :D
Phil97SVT
Phil97SVT's Avatar
The bearings, seals and shims are roughly $150. You can get a set of 3.73s cheap but if you wait until december the 3.90s and 4.10s should be dropping in price.
Phillip
BTW I am installing a set of 3.90s in a 42 carrier later this week. :cheers:
Old 08-23-2002, 04:28 PM
kewlbrz
kewlbrz's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
2.73 case is too weak and small for the bigger gears and torque. I've not heard of anyone using that case.
Old 08-23-2002, 07:07 PM
Rockystoy
Rockystoy's Avatar
Default Re: Can you change the ring and pinion from 3.42 to 3.90 w/o modding the case? (kewlbrz)
Anyone know anyone in the NewYork/New Jersy area that can do this swap? :chevy :cheers:
To Can you change the ring and pinion from 3.42 to 3.90 w/o modding the case?
Quick Reply: Can you change the ring and pinion from 3.42 to 3.90 w/o modding the case?
