C5 Schematic
C5 Schematic
Hi,
Does anyone have a C5 fuse box schematic that you are able to post? I have a 15AMP fuse that has blown twice now. I'm certainly no tuner, but I'm learning. When this fuse blows, it usually does after driving and then restarting. Acts like the engine is "running down" and jumps. I recently had some mods put on such as cove lights, and a lit plenum, but all that runs directly into the battery. I took the car in to a corvette specialist, but nothing could be found. If it is happening, there must be a reason.
Hi,
One under the hood next to the battery and one behind the carpet in the passenger footwell...
Is that the reason you haven't posted what fuse number you are blowing?
