Pink oil leaking ... what is it???
Old 08-14-2002, 01:47 PM
0Vette Stripes
Former Vendor
Vette Stripes's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Pink oil leaking ... what is it???
Suddently, there's some kind of pink oil leaking in the front on the passenger side. It looks real clean oil !!!
What could it be ???
I will jack my car up tomorrow and find it!!!
Old 08-14-2002, 01:54 PM
Patman36
Patman36's Avatar
Default Re: Pink oil leaking ... what is it??? (mike76002)
Is it coming from the very front of the car? Isn't K&N filter oil pink? Do you have an aftermarket filter on the car you just cleaned? Just and idea...
Patrick :cheers:
Old 08-14-2002, 02:15 PM
0Vette Stripes
Former Vendor
Default Re: Pink oil leaking ... what is it??? (Patman36)
Patrick :cheers:
Yes, I do have a K&N filter but I did not clean it for 5 months already :D
and yes, it is very front of the car !!!
The oil temp and coolant temp are just normal ... that why I am still driving it today !!! :cheers:
Old 08-14-2002, 02:16 PM
MarkV
MarkV's Avatar
If you have an automatic transmission, it's probably transmission fluid. You could have a loose line that's leaking.
Old 08-14-2002, 02:20 PM
NJVetteGuy
NJVetteGuy's Avatar
Default Re: Pink oil leaking ... what is it??? (MarkV)
The lines connect on the right side of the car, right into the radiator tank.
MDT
MDT's Avatar
mike76002,
It sounds like transmission fluid, assuming that you have an automatic. If you have an A4, then the fluid runs to the radiator for cooling.
If you don't have an A4, then it may be the orange colored anti-freeze that you are seeing.
Good luck.
Mark
Old 08-14-2002, 02:34 PM
0Vette Stripes
Former Vendor
Default Re: Pink oil leaking ... what is it??? (MDT)
mike76002,
Good luck.
Mark
I got MN6 ... I did touch that pink oil and it is oily !!! I don't think the coolant is oily !!! Well it maybe since I just change my coolant about a month ago but it just start leaking for last couple days !!!
Old 08-14-2002, 04:05 PM
IMQUIK
IMQUIK's Avatar
Could be power steering fluid. :yesnod:
Old 08-14-2002, 04:31 PM
movinup
movinup's Avatar
Default Re: Pink oil leaking ... what is it??? (tshac)
It sounds like your rack and pinion is leaking. I had to have mine replaced
at 1500mi. when it started leaking :(
Old 08-14-2002, 07:00 PM
0Vette Stripes
Former Vendor
Default Re: Pink oil leaking ... what is it??? (movinup)
It is a bit in the middle and tend to be on the driver side a bit !!!
anything is fine since I got GM extended warranty but have to pay 200$ :cry .
Does your car make a loud squeak when you go over a bump in the parking garage??? Mine does make a loud squeak so I will have them check for both if I got the rack and pinion problem !!!
Thanks :cheers:
Old 08-14-2002, 07:02 PM
0Vette Stripes
Former Vendor
That was what I guessed at first !!!
Old 08-14-2002, 07:13 PM
Jim 47
Jim 47's Avatar
Mike, if the spots are at the very front of the car is could be DEXCOOL, the coolant that is in your radiator. It feels like oil and is pink in color. :cool:
Old 08-14-2002, 07:22 PM
0Vette Stripes
Former Vendor
Default Re: Pink oil leaking ... what is it??? (Jim 47)
The DEXCOOL is just cooland brand, isn't it???
So it will be Preston since I just changed it with Preston pink coolant.
I'll keep y'all updated maybe tomorrow. :cheers:
Old 08-14-2002, 08:41 PM
John's vette
John's vette's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
This happened to my car about the same time I started to get LOW COOLANT messages.
Old 08-15-2002, 02:20 PM
0Vette Stripes
Former Vendor
Default Re: Pink oil leaking ... what is it??? (John's vette)
My C5 is a live car :D , it just stops leaking last nite :eek:
I check my cooland level and it is till fine!
Just don't know :confused: :confused:
Old 08-15-2002, 03:07 PM
SFVetteman
SFVetteman's Avatar
Coolant is either orange or green no matter who makes it. Orange is DEXCOOL or another extended life coolant and green is the regular stuff. If you put in 'pink' coolant then, no ofense, you might be a tad colorblind :bb
As far as the leak goes, you might have spilled some and it took time to work itself to the ground. Time will tell.
[Modified by SFVetteman, 11:11 AM 8/15/2002]
Old 08-16-2002, 11:04 AM
VetNutJim
VetNutJim's Avatar
Cruise-In I Veteran
My C5 is a live car , it just stops leaking last nite
Just don't know
If it leaks ENOUGH it won't be "live" for long.
Old 08-16-2002, 11:53 AM
BlackSun!
BlackSun!'s Avatar
Default Re: Pink oil leaking ... what is it??? (VetNutJim)
I had this same problem back in March. I took it into GM and they found it was the waterpump. They replaced it and so far no leak!
Old 08-16-2002, 12:24 PM
0Vette Stripes
Former Vendor
Default Re: Pink oil leaking ... what is it??? (BlackSun!)
That may be it !!!
Where is the water pump so I can just jack my car up and will see those pink coolant dried out there!!!
Thanks :cheers:
To Pink oil leaking ... what is it???
Quick Reply: Pink oil leaking ... what is it???
