c6 oem navigation radio in c5
Hi guys:
Can a c6 radio with navigation unit be installed in a c5? I read that you have to take the vette to gm dealer so vin # isprogram in the computer. Other than that is there any other thing needs to be done if this installation is possible? Thanks JJ
Former Vendor
If your bezel is stock its a 1.5 din and not a double din.
Also the C6 radio is larger than a normal double din sized radio as well.
You will need to go aftermarket to get a double din in the c5 along with a modification.
We can help you with the modification as well and supply everything including the radio needed to do so.
example of a C5 Pioneer NEX 8100 Conversion we did for a customer.
Call me if you would like more info and for me to better explain your options and what is involved
Dennis
608 854 2033
Dennis
608 854 2033
