How to mount magnetic antenna to C5?
I know, I know silly question, but any help would be appreciated.
http://forums.corvetteforum.com/zerothread?id=362558
Thanks,
Matt
Thanks,
Matt
Re: How to mount magnetic antenna to C5? (MJM)
Thanks,
Matt
Thanks,
Matt
The simple answer is you can't...
here is an alternative mount.
http://www.hamstick.com/Tm-1.html
You could just use some 3M double-sided tape instead of the magnet. Just stick the tape to the magnet. :yesnod:
Thanks for the replies. I ended up mounting it on the dash using velcro. The antenna has enough line of sight with the sky to get the GPS satellites and achieve a lock.
Thanks again,
Matt
Thanks again,
Matt
You could use some epoxy and attached a piece of iron (powder coated so it won't rust), to the underside of the body at the place you want to attached the antenna. Then the magnet will stick.
You could use a magnetized piece of iron to insure a good grip. :cheers:
Re: How to mount magnetic antenna to C5? (wwashing)
I have been using a magnetic dual-band ham antenna on my 2001. I will try to find a picture; however, the way I got to work was to lay flat (thiin) steel plate that was spray painted black in the hatch area and have the antenna attached. The dual-band antenna is about 13" high and does not touch the glass on the rear hatch. It looks like a cell phone antenna. It works and is better than no antenna at all. I suggest you try a steel cookie sheet as a test.
On my previous car (Black 96 Coupe) I used a thru-the-glass dual-band antenna mounted on the windshield behing the mirror. It worked great!
Note the antenna behind the mirror.
The coax ran under the mouding
Still looking for a read deck picture. BTW, I have my radio mounted on the bean-bag lap desk and it rides in the passenger seat or is tossed in the back if I have a passenger. The small lap desk and a long power card work great.
[Modified by Dick Kriss, 12:51 PM 8/12/2002]
Location: Recovering from a tragic boating accident in Jacksonville Fl
CI 5-6-7-8-9-10 Vet
Re: How to mount magnetic antenna to C5? (Dick Kriss)
You can get a small metal plate to mount on the dash at a police/fire/EMS supply store. It is used to mount a "Kojack" light to the dash of an unmarked car, volunteer firefighters' POV, etc.
http://www.southwestpublicsafety.com/dasbrac.html
Received 2,051 Likes
St. Jude Donor '13
Re: How to mount magnetic antenna to C5? (RedHot)
For a CB antenna, I bought a "no ground plane" antenna and threaded it through my cargo net (horizontally) in the trunk. Totally stealth and takes up no room. Range is only about a mile but that's enough for me to talk to other cars during cruises which is why I bought it. The blabbering on ch 19 forces me back to CDs after a few minutes.....
[Modified by Dick Kriss, 5:09 PM 8/12/2002]
CI 5-6-7-8-9-10 Vet
Neat link but I don't know how it would help with a 15 to 19 inch wip antenna. Looks like something that would be good for a radar detector.
Don't have an answer for a 2 meter/440 Mhz
Here is what I did:
mikemercury.home.att.net/hamradio.htm
not the best performer, but the best I could do at the time with the goals I had set.
Re: How to mount magnetic antenna to C5? (Mike Mercury)
Mike Mercury: Your radio installation is really neat. I also like the external speaker but not sure of the inverted rubber-duckie antenna.
Dick
Dick
CI 5-6-7-8-9-10 Vet
I'll have to take another look at this if and/or when I decide to mount a rig in the Vette. :yesnod:
Good job. :cool: :cheers:
