tips for HUD install HELPED, but I have another problem :(
1 Post
tips for HUD install???? dash disassembly
does anyone have any tips for me on taking the car apart for the HUD install?????
I have the parts all here..........dash pad, HUD projector and 2002 guage cluster (going to take switches out of it and put in my Z06 cluster)
the HUD install tech tip is more for a pre 99 and doesnt talk about taking the dash out...
SOMEBODY HELPPPP ME :lol:
thanks in advance
thanks in advance
Re: tips for HUD install???? dash disassembly (Ram Air Tony)
Tony:
If you go to the Vetteessentials site and look at the aluminum gauge cluster install, that will give you all the dismantling info with the exception of the dash pad. That will at least get you started until you get the final piece of the puzzle.
Cheers! :cheers:
Cheers! :cheers:
1 Post
Re: tips for HUD install???? dash disassembly (C5 StockSwap)
HEY Stockswap.....ya need some Zaino????? you know how to take it apart dont ya ;) :lol:
thanks
R
A
T
thanks
R
A
T
1 Post
i can get the center poopie out......got vette essentials tips on gauge cluster.....just need to know about the top dash pad :confused:
R
A
T
R
A
T
Cruise-In II Veteran
Cruise-In III Veteran
Trim Pad Replacement - IP Upper
Removal Procedure
Remove the console. Refer to Console Replacement .
Remove the IP accessory trim plate. Refer to Trim Plate Replacement - IP Accessory .
Remove the driver knee bolster trim panel. Refer to Trim Panel Replacement - Knee Bolster .
Remove the instrument panel compartment. Refer to Compartment Replacement - IP .
Remove the windshield defroster grille. Refer to Defroster Grille Replacement .
Insert the DRL and sunload sensors, if equipped, into the nearest openings in the windshield defroster duct. Moving the sensors into the defroster duct provides additional clearance to remove the trim pad.
Remove the windshield side garnish moldings. Refer to Windshield Side Garnish Molding Replacement in Stationary Windows.
Remove the screws retaining the upper trim pad to the defroster duct.
Remove the screws retaining the upper trim pad to the LH and RH hinge pillars.
Remove the screws retaining the IP cluster bezel to the upper trim pad.
Remove the screws retaining the upper trim pad to the driver knee bolster outer bracket and the center support bracket.
Remove the screw retaining the upper trim pad to the passenger SIR bracket.
Tilt the steering wheel to the lowest position.
Lift the rearward edge of the upper trim pad approximately 5 cm (2 in) to provide clearance for the air distribution duct located on the underside of the trim pad.
SLOWLY pull the upper trim pad away from the windshield while guiding the tabs on the LH and RH side of the trim pad past the hinge pillars.
Disconnect the hazard warning switch electrical connector.
Remove the upper trim pad from the vehicle.
1 Post
well I got it all out in about an hour and half
here are the problems as of now.....THERE ARE NO STUDS TO MOUNT THE PROJECTOR TO :cuss
looks like I am going to have to use Kent1999's method with expanding nuts to place into the cowl and hold it down with......but oh well
I took the switches out of the 02 cluster I got (regular C5 cluster) and put them in my 01 Z06 cluster, I didnt have to remove the cluster to do this, with the dash pad out, it was doable :yesnod:
I mounted the HUD projector and connected and it all works, but I have to secure it to the cowl
stay tuned, but I think I have had enough for today.....car is GUTTED :eek:
thanks
R
A
T
thanks
R
A
T
Re: tips for HUD install???? dash disassembly (66ImpalaLT1)
Now that is UGLY! :eek:
Tony,
Let me know if you need any help, I may be able to swing by and give you a hand. I have NO experience taking the dash apart (except when I put my Ripper on), but atleast I'd be an extra set of hands and eyes.
Good luck either way!! :cool: :cheers:
1 Post
i got some pics....it is UGLY without all the stuff on it
it is installed now, just gotta know if hte PAGE button is suppost to light up?!!??!??!
see my other post....and i will post pics later
R
A
T
R
A
T
1 Post
QUIK>.....if I get done in time....I will meet up with ya later and show ya :yesnod:
I am done with the hard part...just gotta cut up dash now :eek:
thanks
R
A
T
thanks
R
A
T
Looks like one heck of a project! Looking forward to having it all finished for you. :yesnod:
vetterdstr :cheers:
[Modified by vetterdstr, 8:16 PM 8/11/2002]
vetterdstr :cheers:
1 Post
Re: tips for HUD install???? dash disassembly (vetterdstr)
Godspeed......I thought I emailed ya friday but I was drunk and email gonbad instead of you :lol: ..... it would have been good to have some hep, but I got it all done :)
rdstr.....how the hell are ya my brudda :) ..... it was a nice project, I can now disassemble the entire interior :lol:
thanks for all the assistance Men
R
A
T
R
A
T
