The Dreaded Oil Pressure Sending Unit (which one)
Hey all,
Well my car has fallen victim, and because I would rather know what the pressure is than risk it going Kaboom I am keeping her off road until I can get the OPSU replaced.
Heres the thing... I heard that AC delco replacements just fail again (read some where that one failed in 12 hours), and that the NAPA ones were ok, but I think I read (and somehow closed the browser that had that page) that there was some people that had replaced their with an aftermarket unit that has been working for years.
I am not 100% sure, but I think it was something like the SMP PS-308?
Is this correct?
Anyone have any other recommendations?
PS. I have also read there are one but then also read there are two OPSU's can someone verify this. I have a 1999 LS1
Is this correct?
Hey all,
Is this correct?
Is this correct?
There's one sensor for the oil pressure gauge - it's tucked up at the back of the engine under the HVAC air intake box.
Now you get to do the fiddly job of changing it!
If my memory serves me correctly from reading MANY posts about this subject, the majority of guys got their OPSU from O'Rielys Auto Parts and
everyone seem to recommend a brass body as opposed to the OEM style Aluminum body. Like I said, I'm going from memory.
Got mine from Advance Auto
I am in the middle of replacing mine right now. I bought a BWD Part # S4202P from Advance. Went to BWD's website and they seem to be a good aftermarket company. It has a brass base, approximately in the center of the picture below:
When mine failed, it read 30 psi on the gauge with just the key turned on. When started, the pressure pegged at 80 psi. Pretty typical failure. I installed my new OPSU, hooked it up, and now the gauge reads 0 psi with just the key turned on like it should. I should have mine done by the weekend!
Borg Warner brass body version is the way to go.
BWD - Oil Pressure Sender
Part # S4202
My AC Delco replacement failed in a month.
2 years and counting on the BW.
Part # S4202
Mine has been going strong for nearly 5 years now. I purchased it at my local Advance Auto Parts store.
Make sure it's the brass version before you buy it. Some old stock aluminum sensors, made by BWD, may still be on the store shelves.
Replaced mine with the one from O'Reillys also, all brass construction. Been working fine now for 4 months. Also, I watched the you-tube video www.youtube.com/watch?v=5PvlDLcyXX8 changed it out in 15 minutes without taking off the intake.
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
The PS308 is the one you want to go with. Its the all brass body one made by SMP. Def want to avoid the aluminum body ones, they are the ones that are known to fail.
As far as R&R goes, the youtube video shows you how to replace it without pulling the IM. You can also spend 2hrs pulling the IM to replace the sender and use that opportunity to clean things up while your in there.
Another vote for O'Reilly's brass unit. Did mine about a year and a half ago, works fine, cost about $40-42 if I remember correctly.
Just checking in, do folks still recommend the OReilly’s or SMP unit? From looking at OReillys all units they have look to be aluminum and i saw some bad reviews on the SMP unit and they show both a PS308 and PS308T unit for the C5 and i can’t tell the difference in them from the details on the website.
Night Owl for life
Received 3,256 Likes
You can get away with any old cheap one as long as you relocate it with a kit so it can be changed in 5 minutes when it fails again
