Need Info on Drive Belt Idler Pulleys
1. Are the 2 idler pulley bearings interchangeable ? A/C & W/P Alt. & P/S
2. Are they replaceable or do you have to purchase the entire assembly ?
Thank you for help .
The Big Guy !
The Big Guy !
Received 3,813 Likes
St. Jude Donor '03-'04
The idler pulleys are cheap.... don't try to find or change the bearings..
the drive idler is different then the Ac idler.. also unless they changed it since I left, OEM pulleys are plastic and Most after market are metal.
Places like Auto Zone, Advanced Auto and Pep Boys have them for 17 or 18 dollars each.
I believe that Dayco will sell you just the pulley, with bearings installed, but keep in mind that the springs in the tensioners will lose tension over time. Therefore, it's best to replace the entire unit.
The idler pulley (what the OP is referring to) and the tensioner pulley (what you are referring to) are two different pulleys.
Cruise-In IX Veteran
Ac drive #36220 (65mm x 17mm x 20mm)
Accessory drive #38006 (76mm x 17mm x 30.5mm)
Now if you need tensioners here are the Gates numbers for them.
Ac tensioner #38196
Accessory tensioner #38194
Typically, when one pulley starts to go they all will in a short time. I replaced all my tensioners and pulleys a few years back with the gates items.
The pulleys are not interchangeable as they are 2 different sizes. Here are the part numbers and sizes for Gates pulleys.
Ac tensioner #38196
Ac tensioner #38196
Thank all of you for your input and additional information.
The Big Guy !
