Help AC Problem
Help AC Problem
I am getting hot air out of the drivers side vents and cold air on the passenger side vents. I remember a post on this a while back, but I can't find it.
Any ideas what to look for?
Google results:
"My Dad's a TV Repairman"
+1 on Corvettes as well as many European cars; low Freon levels will cause imbalance with nothing to do with water valves. Before you worry about coolant stuff, I'd go buy a can of whatever your local parts shop has, and make sure it is the kind that comes with a gauge. Plus it up, and try the air.
cmon op you been here long enough to know that the search function is pretty freaking good..and this is very common
http://forums.corvetteforum.com/c5-t...side-only.html
