K&N Cold Air Intake
Old 08-01-2014, 10:07 PM
UZISOLO
UZISOLO's Avatar
Default K&N Cold Air Intake
Will someone tell me what type of K&N I have and why is there a hole or port in the air bridge .... How to install on a base 2004?
Pls see pics
Upgraded lights .....
see the nipple at the end of air bridge ... I have no hook up for ....
Old 08-01-2014, 10:20 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I use something like that for my PCV system on my 02 ZO6. I have a FAST 90 /90mm TB The 90MM TB doesnt have the filtered air supply port for the OEM PCV system like the old TB and I had to add one. Thats what you have.
Bill
Old 08-01-2014, 10:37 PM
UZISOLO
UZISOLO's Avatar
So Sir will this still on work on my base c5 .... can I just plug the port and keep moving?
Old 08-01-2014, 10:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL! PLUG IT & drive it like you stole it!
Old 08-01-2014, 10:56 PM
UZISOLO
UZISOLO's Avatar
Thx Bill .... I did steal it ... LOL .... I might sell it for the right price.
Old 08-01-2014, 11:17 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,, Look at it this way. If you cut off both ENDS of an hour glass and expect a performance gain,, you dont know how an hour glass works.
Same for your engine. If you add a $3000 CAT Back exhaust system, your engine performance is still limited by:
RESTRICTED, OEM airfilter
Stock compression
Stock intake manifold
Stock head runner CC
Stock valve size
Stock CAM
Stock injector flow rate
Stock exhaust manifolds
TUNING to support changes
SO,,,,,,,,,,,, Changing ANYTHING between the Exhaust manifolds and the MAF requires TUNING!
Old 08-01-2014, 11:34 PM
UZISOLO
UZISOLO's Avatar
Yes, very true sir .... looking at a very nice 20000 miles LS3 engine ... what's your input on installing a ls3 in a c5?
Old 08-01-2014, 11:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your wallet better be flexable!!
You will need:
Engine Compt Harness Mods
PCM/TCM Mods
Crank reluctor hardware/software mods
Knock sensor relocation harnesses
TUNING Up-Grades
Your stock drive train may suffer HP increase issues. READ: Traction, Torque Tube rubber isolators Issues, Rear End Issues,
If your fuel pump suffers at all now,,, Correct before you do the MODs
BC
Old 08-02-2014, 10:24 AM
UZISOLO
UZISOLO's Avatar
Bill,
Do you know of anyone who makes a water protector for the filter part of a K&N .... like a bag or exact cover to let air in and WATER out .... I'm worried about water getting into the engine?
Old 08-02-2014, 10:30 AM
NukeC5
NukeC5's Avatar
Bill,
You don't have to worry about water with that intake. Unless you cut the shroud below it. You can get the hood seal if you are worried about it dripping form above.
Old 08-02-2014, 12:58 PM
UZISOLO
UZISOLO's Avatar
Nuke....
I was looking at your pics of ur car ... what year is it and what is that attached to the rear of k&n cold air kit at the rear of the air bridge?
Looks like wires or ect, just before the throttle body.
Old 08-02-2014, 01:03 PM
NukeC5
NukeC5's Avatar
Nuke.... I was looking at your pics of ur car ... what year is it and what is that attached to the rear of k&n cold air kit at the rear of the air bridge? Looks like wires or ect, just before the throttle body.
Mines a 99. That is the (IAT) intake air temp sensor. Later models had the IAT integrated with the MAF. So if you don't have that, you should have a 5 wire MAF. I do now, but originally it was a 3 wire MAF and two wire IAT.
Old 08-02-2014, 02:51 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can get the traditional hood seal gasket OR, install the same type hood seal that the C6 uses in the front.
I have an 02 ZO6 and it has a trunk lid. I sealed the entire gap between the lid and body using that seal. Works excellent:
Old 08-02-2014, 08:46 PM
UZISOLO
UZISOLO's Avatar
Nice information ... Thx .... I Think I'm ready to have some fun ... Thx fellars.
To K&N Cold Air Intake
Quick Reply: K&N Cold Air Intake
