rwhp
rwhp
Got a question..I have a 99 vert..6 spd that registered 430 rwhp..at the time I had 3:90 gears..now that I have the 3:42 gears back in the car..will my readings stay the same as far as rwhp and torque..any input would be appreciated?
The 342 gear will read higher dyno numbers but I doubt nothing to even think about
The axle ratio will still change the gearing, regardless of using 4th gear for dyno pulls. I have no experience re-dynoing after just changing rear, but I've read that it does make a small difference in numbers.
do you still have the 390 ring and pinion??? also what was your cruising rpm at around 70mph??? i have a 01 6spd and was thinking about changing out the gear ratio to get some extra light to light response but would like to keep my mpg on the hwy
