LS3 Iron Crank?
LS3 Iron Crank?
Hi guys.
Thinking of changing out my 2000 C5 engine. LS1 currently has a A&A supercharger and headers. The trains is a 2004 Z01 as is the rear diff. I was dispointed to see that the 525 hp LS3 has a iron crank in it. If I buy and change the engine and add the blower back on and a 4:10 gear with a progressive Nos system. Will it hold up? Thinking of the 525 Hp unit. I hate to go the extra $$ for the LSX but will if its thought of as best.
Thanks.
Thanks.
The LS3 crank is nodular iron and very strong. Stock cranks are surviving just fine on may 800+hp cars. I kept the stock crank at 610/575 to the wheels with more to come. No issues here.
As long as you don't have any detonation you should be ok, I had a blower on a 500 hp lt1 that I tore down for a stroker rebuild and the crankshaft was cracked, I went with a forged crank on the rebuild to be safe
It's not the crank you should worry about. Using a crate engine, unless forged, and lower compression built specifically for FI, is not your best value/idea. I'd think about a forged piston/rods shortblock, built for the boost you plan on using. You can order the correct CR with whatever heads you want, including your present ones.
