headlights won't move!
I just replaced my passenger side headlight. I plugged both of them in and I used the control to put them down and up. nothing happened but as soon as I turned the car off they both went down. Well I messed with it a little longer and both went back up but now neither will move down or up.
The grounds look good, motors worked for those two times so what else could it be?
codes ain't the issue here....unplug them again and then try again
C5Z06CE
Well I clicked the high beems on one time and then my lights came on and the headlights went up and down! Good news but the bad News is that the headlight is making the loud gun shot noise from the motor. The adjustable part on the headlight motor seems to keep spinning and when I try to tighten it, it seems to be stripped I guess? I have other headlight motors is it worth it to swap it out?
