Turn Signal Issue
Old 07-25-2014, 04:17 AM
BigKleib34
BigKleib34's Avatar
Default Turn Signal Issue
Hey guys quick question. In my 2000 C5, I have turn signals that work when they want to. I've read up on how it has been a common issue traced back to the hazard switch...
Is it a better idea to replace the hazard switch, clean the contacts on the current one, or buy the bypass?
I don't really mind spending the $70 on the bypass, but if I can fix it for cheaper (or free) I most definitely will.
I'm also concerned about my hazards not working properly with the bypass installed, but I guess that's something I can to talk to the Corvette Enhancement guys about should it seem necessary to go that route.
Old 07-25-2014, 08:18 AM
dadaroo
dadaroo's Avatar
Sure sounds like your Hazard switch is your problem. More likely than the Multifunction switch. Replacing it is not that hard and for only about $25 it is cheaper. There are a couple of ways to do it and I can go over those if you want to PM me your number.
When I did mine I left the old one in the dash for cosmetics and relocated the new one under the dash. If I need the hazards on it is easy to reach and it can be replaced in 20 seconds if needed.
To me a great option is to just buy a used GM harness section (GM P/N 12163776)
and unplug yours and plug in the replacement with a new Hazard switch. This will be relocation similar to mine. No more work than a Hyperflash install. Easy to find them and I bet VetteNuts here has at least one. I almost did this but had my radio out to replace with a CD unit so I didn't buy the harness.
My relocation info:
http://forums.corvetteforum.com/c5-t...elocation.html
Quick Reply: Turn Signal Issue
