Callaway Honker Intake Filter Cleaning Question
Received 2,673 Likes
2018 C5 of Year Finalist
I'm curious to know from fellow C5 owners with Honker CAIs installed, what is the easiest way to remove it in order to clean the filter element? Since the Honker comes with a custom air bridge, which of the four clamps do you disconnect to remove the Honker without disconnecting components that don't need to be disconnected just to clean the filter? Thanks!
Edit - I was able to remove it by loosening the first bracket towards the front of the car that connects the air bridge. I was then able to turn the Honker without removing the attached hose to gain full access into the K&N filter.
