Battery Drain - Windshield Wiper / CD Player
I seem to have run into a weird issue and need some guidance
Last week I got my Vette washed at a touch-less car wash. As I was driving home my windshield wipers turned on by themselves (even though the *** is in the off position) No matter what I did I could not get the Windshield wipers to turn off.
Also my CD player (I have the 12 disc changer in the trunk) stopped working, basically every CD I tried to play the screen said "ERR"
I parked the car and decided I would take a look at it during the week. I went to go start my car up 5 days later and the battery is totally drained (locks wont even work)
If anyone could point me in the right direction it would be very helpful before I bring it in to a shop.
Thanks in advance!
Thanks in advance!
You can pull the fuse on the wipers to prevent a drain. I doubt the CD player is draining the battery. Did water get in there too?
DO NOT charge a dead battery in the C5 without at least disconnecting the battery (negative cable preferred). Chargers do not put out a pure DC voltage and the square DC wave can pound the electronics since the dead battery cannot help filter these out.
Thanks in advance!
Thanks in advance!
Regarding the wiper motor it may just need to be replaced. I also use to go to a car wash and afterwards my wiper motor would go crazy all by itself, off and on, stopping in weird positions etc... I believe the problem is with the car wash, because it only happened after I drove through. My car wash used those huge jet like dryers which blew water and air so hard it looked like the hood was gonna pop up. Those jets got water into my wiper motor and made it go haywire. I had to replace the motor, not a big job but read up on it because some places like Autozone give you the wrong motor.
Lastly your battery could of drained because you left the dome light on or maybe you had the doors open or hatch open for so long that it killed the battery. If your battery was weak to begin with then something like that could of caused your dead battery. I drained my battery because I left the dome light on once and when I was working on the car with the hood up and doors open the battery drained. I bought a new one at Sears.
I hope this helps you, Good Luck!
