AC Fan Motor
AC Fan Motor
I have searched the forums but I can't find one I saw a while back that shows how to replace the fan motor. Does anyone have a how to or have that link?
St. Jude Donor '14
2001 Chevrolet Corvette V8-5.7L VIN G
Vehicle » Heating and Air Conditioning » Blower Motor » Service and Repair » Blower Motor and Fan Replacement
BLOWER MOTOR AND FAN REPLACEMENT
REMOVAL PROCEDURE
Remove the I/P lower insulator panel - RH. Refer to Closeout/Insulator Panel Replacement - IP Lower (LH) or Closeout/Insulator Panel Replacement - IP Lower (RH) in Instrument Panel, Gauges and Console.
CAUTION: Unplug the blower motor before removal. Blower motor case contact with any ground may start the tan and cause personal injury .
Disconnect the blower motor electrical connector.
Disconnect the blower motor cooling tube from the HVAC module.
Remove the blower motor retaining screws.
Remove the blower motor from the HVAC module.
INSTALLATION PROCEDURE
Install the blower motor to the HVAC module.
NOTE: Refer to Fastener Notice in Service Precautions.
Install the blower motor retaining screws.
Tighten
Tighten the blower motor retaining screws to 1.7 N.m (15 lb in) .
Connect the blower motor cooling tube to the HVAC module.
Connect the blower motor electrical connector.
Install the I/P lower insulator panel - RH. Refer to Closeout/Insulator Panel Replacement - IP Lower (LH) or Closeout/Insulator Panel Replacement - IP Lower (RH) in Instrument Panel, Gauges and Console.
REMOVAL PROCEDURE
Tighten
