Trying to learn, can you all check my data?
Heres what I got so far:
LS engine specs:
LS1
bore: 3.898"(99mm)
stroke: 3.62"(92mm)
Compression: 10.1:1
Chamber: 66.67cc
Intake runner: 200cc
Exhaust runner: 70cc
Intake valve diameter: 2.00"
Exhaust valve diameter: 1.65"
Cam: 198/208 .467/.479 116
Throttle body: 78mm
LS2
bore: 4.0"(101.6mm)
stroke: 3.62"(92mm)
Compression: 10.9:1
Chamber: 64.45
Intake runner: 210cc
Exhaust runner: 75cc
Exhaust valve diameter: 1.55"
Cam: 204/211 .525/.525 117.5
Throttle body: 90mm
LS3
bore: 4.06"(103mm)
stroke: 3.62"(92mm)
Compression: 10.7:1
Chamber: 68cc
Intake runner: 257cc
Exhaust runner: 86cc
Intake valve diameter: 2.16"
Exhaust valve diameter: 1.59"
Cam: 204/211 .551/.522 117
Throttle body: 90mm
LS6
bore: 3.898"(99mm)
stroke: 3.62"(92mm)
Compression: 10.5:1
Chamber: 64.45cc
Cam: 204/218 .551/.547 117
Throttle body: 78mm
LS7
bore: 4.125"(104.775mm)
stroke: 4"(101.6mm)
Compression: 11.0:1
Chamber: 70cc
Intake runner: 259cc
Intake valve diameter: 2.20"
Exhaust valve diameter: 1.61"
Cam: 211/230 .591/.591 120
Throttle body: 90mm
LS9
bore: 4.06"(103mm)
stroke: 3.62"(92mm)
Compression: 9.1:1
Chamber: 68cc
Cam: 211/230 .562/.558 122.5
Throttle body: 78mm
LS engine specs:
LS1
bore: 3.898"(99mm)
stroke: 3.62"(92mm)
Compression: 10.1:1
Chamber: 66.67cc
Throttle body: 78mm
LS2
bore: 4.0"(101.6mm)
stroke: 3.62"(92mm)
Compression: 10.9:1
Chamber: 64.45
Throttle body: 90mm
LS3
bore: 4.06"(103mm)
stroke: 3.62"(92mm)
Compression: 10.7:1
Chamber: 68cc
Throttle body: 90mm
LS6
bore: 3.898"(99mm)
stroke: 3.62"(92mm)
Compression: 10.5:1
Chamber: 64.45cc
Throttle body: 78mm
LS7
stroke: 4"(101.6mm)
Compression: 11.0:1
Chamber: 70cc
Throttle body: 90mm
LS9
bore: 4.06"(103mm)
stroke: 3.62"(92mm)
Compression: 9.1:1
Chamber: 68cc
Throttle body: 78mm
