Engine sputters at high rpm under load
My stock C5 breaks-up at high rpm. 32K, dry engine, not sure if/when plugs/wires were changed, idles fine runs good under normal driving. I can't do much mechanically. Any recommendation?
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would say, start with new GM Red Performance wires, check the air filter, clean the MAF with MAF Cleaner. Clean the throttle body/blade. Check the fuel pressure. Its TOUGH to check it at speed when it falters but, you may be starving for fuel at higher RPMs. Something to think about. Get the wires at www.gmpartshouse.com Good price good people...
The DTCs will help us go in the correct direction. What is the condition of your battery??? C5s are battery voltage critical/ I would have it and the charging system checked to make sure everything is good there.
When the engine falls on its face, do you see the CHECK ENGINE LIGHT (CEL) flashing????????? Important info!!
Bill
WOW! Not much I can do without you reading the DTCs using the DIC. When the engine falls on its face, SAFELY,, pull up the DTCs just after the event and see what pops up (without turning the engine off).
Bill
Bill
Bill
Bill
CI 6,7,8,9,11 Vet
St. Jude Donor '08
D Bolt - If you ramp up slowly, does it make the same symptoms? Or, is it ONLY under WOT, ramping up really fast, and after 5200 RPMs (or thereabouts) it feels as if you are hitting Rev Limiter?
I had this issue what I am describing and it was a cracked spark plug. Usually comes with a MISFIRE engine code.
Swap your spark plugs, or, check them very carefully, one by one.
Mine had a hairline crack and was hard to see. So, under normal driving, it was fine, but WOT, it was arcing under load.
I'll start with the suggested basics, hope your was resolved.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
