Charging system Failure Message
Ok this morning got in to go to work and started up the vette. I almost missed the message but it flashed on the screen and went away. I didn't clear it or anything. Voltage was 14.2 and all seemed fine. Looked at the codes and no codes other then the two that are always present. PCM one that is there from the Tune and the TPS one from traction control. No issues starting or anything and like I said I almost missed the message I just happened to glance at the DIC.
Hopefully just a glitch. If it happened early on during starting like you describe that could be the explanation. Have you done anything lately (~ 6months) that might affect the charging system? Let us know if it happens again. Could be a loose connection or a bad lug.
Not at home with the FSM and other info to verify if that message should have an associated code.
Thanks. Started it 4 times after and nothing. Will keep an eye on it hopefully it's nothing!!
