McLeod Clutch Comparison & Promotion @ Hinson Motorsports
Old 06-11-2014, 12:56 PM
0HinsonSuperCars
Former Vendor
HinsonSuperCars's Avatar
Location: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Default McLeod Clutch Comparison & Promotion @ Hinson Motorsports
$$$ WEB PROMOTION - BUY ONLINE AND IT SHIPS FREE $$$
-Lighter than stock pedal feel
-Bolts to stock factory flat flywheels (LS1/LS6 only)
-Easy Installation
-Organic & Metallic disc facing available for smooth & even engagement
-Smooth engagement with excellent release qualities
-Low Rotating Mass (moment of inertia) for quick revs
-Includes CNC machined and anodized flywheel adapter ring
-Blanchard ground floater with multiple straps to reduce noise for streetability
Balancing of you clutch and flywheel together to reduce vibrations is also available
McLeod Street Pro <- CLICK HERE FOR PRICING
McLeod RST Street Twin Disc 800HP <- CLICK HERE FOR PRICING
McLeod RXT Street Twin Disc 1000HP <- CLICK HERE FOR PRICING
McLeod Street Twin Disc & Flywheel 1200HP <- CLICK HERE FOR PRICING
Mcleod Billet Aluminum Lightweight Flywheel 14LBS <- CLICK HERE FOR PRICING
McLeod Billet Steel Flywheel 24LBS <- CLICK HERE FOR PRICING
Old 06-23-2014, 07:38 PM
David426
David426's Avatar
What is the street pro rated at? I've got an LS6 with 450rwhp,, Looking for a clutch and flywheel.... What is the total weight of the street pro clutch/pressure plate kit?
Old 06-24-2014, 11:33 AM
0HinsonSuperCars
Former Vendor
The Street Pro is rated at 400hp so you would need to step up to the RST to give yourself a little room to grow as well. the RST is a great twin disc clutch that has a stock like pedal feel but enough clamping force to hold 800hp at the flywheel.
Old 06-24-2014, 01:28 PM
David426
David426's Avatar
Can you send me a pm on price for the full Clutch set up and flywheel, with the weight of each too? 2002 z06.. Thanks
Old 06-25-2014, 10:13 AM
0HinsonSuperCars
Former Vendor
PM Sent. Thanks for the interest.
Old 08-18-2014, 06:02 PM
0HinsonSuperCars
Former Vendor
Thanks for the orders.
Old 08-25-2014, 10:01 AM
0HinsonSuperCars
Former Vendor
Get these while they are in stock!
To McLeod Clutch Comparison & Promotion @ Hinson Motorsports
Quick Reply: McLeod Clutch Comparison & Promotion @ Hinson Motorsports
