Hinson Motorsports Trickflow Heads and Flow Numbers
Former Vendor
These are the baddest cathedral cylinder heads on the market!
Trickflow "As Cast" 220cc
Trickflow CNC Ported 215cc
Trickflow CNC Ported 225cc
Trickflow CNC Ported 235cc
Trickflow CNC Ported 245cc
Increased Piston to Valve Clearance
- Allows you to run a larger camshaft with more PTV clearance than a stock head
Thick Deck (.600")
- Withstands higher cylinder pressures when using forced induction & nitrous
Extreme Dual Valve Springs
- Rated for .650" Lift
- 450# Open, 150# Closed
Stainless Intake & Exhaust Valves
- Withstands higher exhaust temperatures
6 Bolts Per Cylinder Option (Available on 235cc & 245cc)
- Adds 2 more bolts per cylinder, which will withstand extreme cylinder pressures
During the development stage, Trick Flow engineers determined that the valve angles needed to change from 15* to 13.5*. This change decreased valve shrouding, increased mid-lift airflow, and increased rocker arm-to-valve cover clearance. Testing also proved that relocating the spark plug position in the combustion chamber further enhanced combustion along with mid lift airflow and improved the integrity of the casting in the chamber area. Trick Flow also added additional material to the decks (.600") and to the rocker arm mounting pads to improve high rpm valve train stability.
Thick Deck (.600")
Former Vendor
Flow Numbers
Roller Rocker Arms
Yella Terra Ultralite Shaft Mount Non-Adjustable Roller Rocker 1.7 Ratio (LS1/LS2)
The use of roller rocker arms is recommended with cylinder heads having bronze guides. Using roller rockers will reduce the wear on the guides thus reduce oil consumption down the road.
Stock rockers scrub the valve tip above .550" lift, the more you shim a stock rocker, the worse the scrub becomes. A stock rocker should work like a rocking chair to open the valve, which is not at all how a roller rocker works. A stock rocker will have a wide pattern, if you shim it up to reduce the width of the pattern, you will increase the scrub, and this scrub is the source of the friction that causes tip and guide wear. A roller rocker works just the opposite, as you shim it up it reduces the sweep pattern, since it rolls there is no scrub.
Pushrods
Comp Cams Chromemoly Pushrods
Available in .025" increments
Comp Cams Pushrod Length Checker
A .100” longer than stock pushrod is required with these heads.
Head Gaskets
Trickflow "As Cast" 220cc (3.9 Bore)
3.910 Recommended
GM LS1 5.7L Multi-Layer Steel Cylinder Head Gaskets
Cometic 3.910" Multi-Layer Steel Cylinder Head Gaskets (.040")
Cometic 3.910" Multi-Layer Steel Cylinder Head Gaskets (.051")
Trickflow "As Cast" 220cc (4.0 Bore)
4.060 Recommended
GM LS3 6.2L Multi-Layer Steel Cylinder Head Gaskets
Cometic 4.060" Multi-Layer Steel Cylinder Head Gaskets (.040")
Cometic 4.060" Multi-Layer Steel Cylinder Head Gaskets (.051")
3.910 Recommended
4.060 Recommended
4.150 Recommended
GM LS7 7.0L Multi-Layer Steel Cylinder Head Gaskets
Roller Rocker Arms
Pushrods
Head Gaskets
3.910 Recommended
4.060 Recommended
3.910 Recommended
4.060 Recommended
4.150 Recommended
