Any one with Vararam expreiencee?
I need some help! I'm installing the Vararam VR-B2 on my 03 Z06. I have it installed from the grill openings to the airbox. Now I just need to put the Power Duct in its place. My problem is that the red couplings that go between the airbox and the MAF, the MAF and the power duct and between the power duct and the throttle body are too small. When I hold the coupling next to the powerduct, MAF or throttle body they all appear to be the same size. I cannot get the coupling to fit over the top of the desired piece. Does anyone who has put this system together have any suggestions?
Be careful you don't dint in the side of the air box connector forcing the coupler on. On mine, I just have the MAF forced inside the air box. A little heat applied to the plastic and it plugged right in.
Thanks Pit-Man & lionelhutz! I have been fighting with this for a couple hours with a screwdriver, two screwdrivers & three screwdrivers! I'm going to try the oil and then the heat. Hopefully this will get it done. I just recognized that there are three slightly different sizes so maybe I just need to get them in the right order.
Correct
