ac-heat
Old 05-02-2014, 06:46 PM
campbellbob
2nd Gear
campbellbob's Avatar
Default ac-heat
Continue to have problem with cold air on drivers side and hot air on passengers side. Have unplugged fuses and unhooked battery with no results. Also, turned unite off in heat mode and the started car and switched to cold, again no results. thanks
Old 05-02-2014, 07:06 PM
Idaho Hot Rod
Idaho Hot Rod's Avatar
a lot of info on this. Check your hvac codes and see what it says. Its probable the hvac actuator with a cracked plastic gear. I had the same problem and just changed my out and it fixed it. If it's the driver's side actuator it's not to bad to change. If it's the passenger side then it's a lot harder. Check and see if you have any codes and if so you will be able to tell which side is bad.
Quick Reply: ac-heat
