C5 Fan Shroud Install
Does anyone have a secret way of getting the fan shroud between the radiator and engine? I have tried from the top; horizontal, vertical then turning the left lower fan up. I tried to install from the bottom. I have removed upper radiator hose.
Nothing has worked.
Any proven suggestion would be appreciated. Thanks
This means it is time for a beer.
Nothing has worked.
Received 1,261 Likes
I think it's easier from the bottom... my radiator is tilted back and it's easier if I remove the sway bar to give me plenty of room... been awhile since I've looked at a stock one but you might have enough room without having to remove the sway bar... just push up from the bottom to release it from the tabs on the radiator and if installing just push up until it clears those tabs and it will fall into place
This is an answer to my own post. Thanks to others that replied. Perhaps what I discovered will help others.
The fan shroud is difficult to remove and install do to lack of clearance. Whether just installing the shroud or installing the radiator. I recommend the following:
Remove the radiator hoses. Drain the coolant if you haven't already. Using rope, gently cinch the radiator forward looping one end to the radiator an the other to the hood levelers near the front of the car. Then slide the shroud into the clips on the radiator. Connect the radiator hoses. Then cut the ropes. It is very simple and much easier to do than any other solution recommended in the Corvette Service guide or the forum.
Also, as pointed out in another Forum post, cut a piece of cardboard the size of the radiator to cover the radiator vents to protect them from damage. In the attached picture the blue line in painters tape used the hold the cardboard to the radiator. Once the radiator and shroud are in place remove the cardboard.
See attached picture:
