Wire coming out of battery
I have a quick question. There seems to be a wire coming out of our battery's positive connection cable. We never noticed it before. Can anyone tell me what it is? I'm guessing for quicker and more accessible testing? Thanks
Probably a battery tender. Where does it lead to? Is there a connector at the end? A lot of battery tenders/trickle chargers have cables that are installed to the battery terminals and then you plug the cables of the charger into them.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
A picture would really help.
I agree
Yes, I want to get a picture but I'm not home now, but I'll get one up in a few hours. I looked at this diagram and see a section coming off the positive cable, so it looks normal. http://cdn3.volusion.com/ekutc.vrlsy...jpg?1347959337
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The C5 OEM Positive battery cable splits into two wires. One wire goes directly to the starter solenoid and the other goes to the engine fuse box B+ terminal
The Negative battery cable also has two wires. One goes to the engine block and the other goes to the frame Chassis Ground G-104/108
yes, you're right, it's connected to the fuse box, but loosely. What are the second wires for? Thanks a lot! just hoping it was normal and not some add on. Are having problems with our AC and have been looking at other threads on that.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have NO idea what that wire is but it isnt stock. The terminal on the fuse box (in that picture) has all the correct connections.
Find out if that wire is powered. If it is, I strongly recommend covering it in electrical tape or removing it.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Use the DIC and read and post the DTCs
BC
BC
Looks like the wire has an eyelet connector, it's tough to make out in the picture. That connector was once attached to the 12v stud at the end of the fuse box, so it's a power wire to something (?). If I had to guess it looks like it could be a power wire to a stereo amplifier considering it's loomed with the power wires that feeds into the passenger compartment.
I installed my battery tender cables to the ground and the B+ terminal on the fuse box. It is a clean, safe installation. That is not good.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Neither of your temp door actuators are functioning Either there dead, broken gear of not being powered
Can you hear them cycle when you pull and reinsert the fuse??
BC
BC
great! I'll try and test later for sure. Have an appointment at the dealer tomorrow too. If the actuators don't work, do you think they're the ones under the dash near the radio? or are they located some place else? I'm looking at another post you helped someone out with the same issue now. Great pictures.
never mind that last question. I see both are behind the dash then now. interesting. those control the heat and air temperature of the air conditioner then? Do you think it could also be the ambient air flow sensor? Or that wouldn't be part of the problem
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OH BROTHER! If you have the stealership fix those actuators,,,,, you better reload your check book with a LOT of cash!
Yes,, those actuators control whether the air moves across the cooling coil or the heat coil or a combination of both for temperate air.
You will NOT like the price for the repair!!!!!!
Its not that difficult to do the job yourself
