How to lower my c5 zo6 on stock bolts???
make sure to take before and after measurements on the same ground and measure multiple places. if you get a corner 1/4" off for example you'll shift over 100lbs of weight
if you use the fenders the popcicle stick method is much more accurate than eyeballing. you use a stick across the rim of the fender and run the tape to the stick. prevents your eyes from messing with you as you can touch the stick to the tape
you don't do it by measuring to the body/fender from the ground. The car was set up at factory for correct corner weight. In order to not screw this up you want to back off each bolt (front and rear) the same amount of turns so you keep current corner weight distribution. This way you keep the rake the same also. I looked at both front bolts and saw which one would be the least I could back out. The front left could only be backed out 2.5 turns. I then backed out all four corners 2.5 turns. Easy to move back to stock setting now in future also. A search will reveal is this the best method. good luck.
it's not ideal but you can get the hubs within an 1/8th if you're skilled
a proper set of scales is really the only way to do the car correctly
I should have said a search that you need to put the time into sifting through good and bad info. People do the fender method all the time doesn't mean its right like you know. You can't search for an answer and go by the first few posts you read, etc. From all the posts I read, turning each bolt the same amount of threads is the best (and easiest) method. Of course scales are best but obviously most don't have.
fenders vary car to car and with some cars {like mine} they are accurate as checked against the knuckles. the problem with fenders is if one is set 1/4" higher on the body, which isn't uncommon, then you will be off on the knuckle, unless you check
you can also check the jacking points for a second reference
it's really not, as the springs have aged turns don't always lower the same amount. if the car has previously been lowered your baseline is also off. i did that same turn method and wound up being off over a 1/4" corner to corner.
