Any shops that can replace a slave cylinder – Albany NY area
Anybody know of a shop that can replace a slave cylinder within driving distance of Albany NY.
Have 99 coupe with 80K on it and I can’t shift into gear with the car running. No pressure on clutch petal at all. I think it’s the slave as I see some discoloration on the exhaust that may be coming from a slow leak in the slave. I’ve had car for about 3 years and I’ve put on about 3K miles without issue but have no idea if the clutch has ever been replaced so that may need to be done also if worn.
Any shop within 200 miles of Albany that has experience in this. I do not want to have to take it into the Stealership.
Distance is not really the issue, just want to find someone that will do it right.
