Motor damage from loss of oil - how long before it shows?
Old 02-09-2014, 02:06 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
Default Motor damage from loss of oil - how long before it shows?
Any way to check before paying for track day? Accumsump busted and dumped all my oil. Drove about 100 yds with zero oil pressure. Have driven about 100 mi since and it seems to be doing OK, no unusual sounds etc. How many miles before I can cut up oil filter and look for metal? Any other things to check? Motor is a forged aluminum LS2 if that matters.
Old 02-09-2014, 02:37 PM
martysauto
martysauto's Avatar
St. Jude Donor '14
As long as you weren't running it hard, it's probably just fine. It's a benefit of running Mobil one! Is your oil pressure the same as it was before?
Old 02-09-2014, 03:14 PM
ZeeOSix
ZeeOSix's Avatar
Remove just the filter and put a new filter on and top off the oil level if you want to cut it open now. 100 miles since the incident is plenty of miles for the filter to catch anything that might have been a result of the oil loss.
Old 02-09-2014, 03:22 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
You definitely would have known by now. Sounds like you got lucky on this one.
Old 02-09-2014, 04:18 PM
jcgunn
jcgunn's Avatar
If you really want to go crazy, you can do an oil analysis. This will tell you if you are CURRENTLY making any metal. Costs about $25 from Blackstone Labs.
Old 02-09-2014, 04:45 PM
racebum
racebum's Avatar
if it's not knocking or idling weird you're probably fine. it's possible you added some wear to the rings and bearings but that's about all
maybe 5,000-10,000 miles of driving in 100yds as a wild *** guess. a little metal on metal contact, not under load isn't going to destroy anything. or, if it had, you would know it
i agree on cutting open the filter and spending $25 at blackstone for an oil analysis
it's possible virtually no damage was done
google blackstone oil labs and send them a sample
if you were really concerned about the rings you could do a cylinder leakdown test, oil pressure would show you the health of the bearings
Old 02-09-2014, 06:23 PM
waddisme
waddisme's Avatar
Didn't think about doing an oil sample analysis. Actually had last Blackstone sample done last summer, so I have 2 reports to compare to. Will probably do the oil filter thing just for peace of mind.
To Motor damage from loss of oil - how long before it shows?
Quick Reply: Motor damage from loss of oil - how long before it shows?
