Steering Wheel Off Center/ 02 Z06
Had my 02 Z06 since July.
Drives straight, doesn't pull at all one way or the other. (Of course, checked on a straight road as its hard on back roads). Very, very tight car.
One thing that is annoying through, as that when driving straight the wheel is to the left about 20-30 degrees. Not horrible, and honestly my truck is the same way, but I would like to try to straighten it up this winter.
I was thinking just loosen the jam nuts on the tie rods and go 1/2 a turn on each one or so (obviously, pulling the one in and extending the other) to try to straigten it up.
It had VERY worn out OEM F1's on the front which are now replaced by Potenza's and it was hard to tell if they were wearing funny. IT came with new Potenza's on the rear. After about 4000 miles I am observing no obvious wear.
Anyone have any experience or success doing this?
Maybe just going and getting a 4 wheel aligment is just the best option.
Thanks all!
Thanks all!
alignment is the best option. they can center your wheel and set your toe and camber where you want it
vette is a SUPER easy car to align. most firestones have modern racks and often run $69 coupon specials.
bring in your own specs and have them set the car
or,
just do factory default which is what they will do if you say nothing
one thing i would add is to mildly toe in the rear. for some insane reason the factory has no toe in out back which increases the car being darty in the rear end. .05 in each side makes a difference and has next to no effect on tire wear
the front spec is .04 in each side. if you want the car to turn in faster you can change that to .02 to .00 the drawback of this is it won't track quite as straight, just depends on what you want more. straight line tracking or turn in speed
or,
I had that problem, had to keep the wheel at 1:00 to go straight. Got a 4 wheel alignment and problem solved.
