C5 Cooling Issue
C5 Cooling Issue
So not to long ago i had an overheating issue with my Corvette. Couldn't figure out why it was overheating because the water pump and thermostat were working fine. After searching around the internet and these forums for awhile i read to flush the radiator. After flushing the radiator and feeling it with the proper amount of coolant it was still over heating. I was very frustrated with the whole ordeal. I don't know why i did what i did next but i ended up flushing it again and just putting in straight Water. Now for some reason that seamed to fix the overheating issue. Being the dumb person i was i forgot to come back later and put the proper antifreeze in later and this winter my system froze up ruining my water pump. So after replacing the water pump and thermostat (just to be safe) with a 187 Themo i filled it back up again with the proper Antifreeze mixture and low and behold I am overheating again. Anyone have any insight on this problem because that would just be great.
Something else, I am over 100k miles with the stock radiator but when flushing it comes out easily enough and there is no damage to the fins on the radiator at all, looks all good. No debris or anything came out. And like i said works fine with straight water running through it.
I'm pretty sure but at this point ill try anything, What does the trick consist of? Just blowing out the coils with an air wand?
Like i said before to when i run straight Water it doesn't over heat at all.
there's the issue
ac delco 20889 will fit most c5s
cooling efficiency goes down as the radiator gets plugged with crap in the fins. you also have internal scaling
when it's 100deg in august you may have issues again
