c5 LG rear drag spindles on a c5 pics
well figured i start and share my own tread to help anyone doing this allowing u to install 15" wheels on the rear of any c5.c6 is similar just the lower control arms are a bit different but same milling required...pics to come in few days after i assemble all my modded parts back into car
thanx to JW racing and Fabrication on the machine work on the parts .... looks factory
I put the wheels on today jus waiting for my gf to get home we can roll her out and shoot some pics..i think were gonna like it... not connecting the caliper lines yet cause all 4 goin out for powder coating
post pics in few hours
fitment is very good...the pro fits perfect with the rts and the stock quaters....
Once i can drive it im sure it will settle down more...def want to get the *** down
now i need some help with the fronts...
My options are
18s with a 26" tall M/t s/r radial skinny
17s with the new 28" skinny s/r radial..hmm
My options are
Spindles
I installed my spindles about a month ago. I'm running MT 275-60-15 radial (Pro style almost slick) on rear with Welds. Only thing I had to touch was rear brake calipers a little...otherwise it all worked fine.... 1999 C5.
Front I went with M & H skinny radial, Welds, and used 3/8 spacer to clear brakes. I also added longer front studs to maker sure I had nuts secure enough.
Any pics to share?
The pro 275s fit perfectly like they werre made for this fitment..lol
Awesome! I can't afford the LG spindles otherwise I'd be all about the 15" rims . I run the 16" CCW classics and the best tire I can run is the 26"x11.5" MT ET streets. Would love to run a full drag tire in 15" rim size!
Amazing how tight the fit is even with 16"! I had to shave on the upper part of the spindles and underside of the lower control arms to stop them from rubbing!
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
well got the car down on all 4 and the control arms are still to close to the wheels maybe like 1/16" jus sitting..
wow how much do u have to trim
